A peek under the skins of my LTX-SE
Apex2006
McHenry, IL
Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Installing my HIDs and LEDS this weekend. Once the side panels are removed, the entire hood can be removed with one single wiring connector under the cluster. Surprised at the tape job on the wiring harnesses. Interesting location for the brake rotor assy......
Beautiful! Not a spec of brake/belt dust in sight! I'm sure it will stay that way! Lol! ;)
I wanted to peel the plastic off a xf7000 today at tha AC dealer to have a peak, but I figured it would take too long. Thanks for the pics.
Did you guys get a brocure with the sled that gave info on such things as secondary spring,helix angle,primary weights and primary spring,p/n's and helix angle,gear ratio and size's etc?
Defentaly a artic cat tape job ... This is going to be my first new sled I really want quality that's why I ride Yamaha even a small thing like the tape job on a brand new sled has me thinking...
rough rider said:
That messy looking tape job was never seen on a true yamaha, looks like a little kid wraped up that harness lol :Rockon:
I was thinking the same thing.
Yes it is. Noticed that first time I saw one. Is wierd tape also. Has a sheen to it. Probably leave it alone and next spring pull the harness which will be a good opportunity to find any long term rub points.
Probably was a little kid...in Mexico. 5 years ago the wiring harnesses for Arctic Cat were made here in Bemidji, MN. Not anymore. The good news is we haven't had any problem with them other than some routing issues during assembly. Check the routing and zip tie at will!
Let's see the LED's. What kind are you putting on? Where are you installing? Picking mine up this weekend and already have ideas.
Other than the bad tape job, everything else seems to be okay. The LEDs are installed and I am getting my HIDs tomorrow. I have the sled stripped and will be putting back together in the next day or so. I will have pics when done with it. :-o BTW, every fricken screw is a torx screw, PITA!!
yamaha1973 said:
Yep, and to make it even better there are multiple thread pitches and driver sizes.
I installed my HID's this evening. You have to pretty much disassemble the entire hood to get enough leverage to reinstall the headlight bulb keeper thingy's, to mount the ballasts (i riveted them on), and secure all the wiring. It took a good 3 hours from start to finish.
I'm not a fan of the Cat hardware/fasteners.
