Aberfoyle Power Sports in Ontario Canada is a distributor for J&T Products Wheel kits!! J&T is the number one seller by far of premium heavy duty wheel kits! Aberfoyle power sports in Ontariovand new has all the wheel kits for all the Cats all the way back to the Firecat days. kits for the Yamaha Vipers, Sidewinders and the new turbo Riot in house !! Aberfoyle now has the small idlers with larger bearings. The 5.5 super duty idler wheel replacements in STOCK right now!
Aberfoyle also now carries the DMC TOP GEAR FIX and the Brass fork pads for the Sidewinders, T-Cats and all 998's. This is a permanent fix that has been proven by 1000"s of customers so far with no issues. They are also in stock!!
Aberfoyle Power Sports 1 519-763-1401
Ask for Scott or Jeff
Fast
- Sep 25, 2018
What's the 8.5" stealth kit worth?Aberfoyle Power Sports in Ontario Canada is a distributor for J&T Products Wheel kits!! J&T is the number one seller by far of premium heavy duty wheel kits! Aberfoyle has all the wheel kits for all the Cats all the way back to the Firecat days. kits for the Yamaha Vipers and Sidewinders in house also!! Aberfoyle now has with larger bearings the 5.5 super duty idler wheel replacements! All in STOCK right now!
Aberfoyle also now carries the DMC TOP GEAR FIX and the Brass fork pads for the Sidewinders & T-Cats that is a permanent fix that has been proven by 1000"s of customers so far with no issues. They are also in stock!!
Dont wait till it time to ride because parts sell out fast theses days and back orders can be long!!!
You would need to contact them. I am in the states.What's the 8.5" stealth kit worth?
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
all my JT wheels turned into stop signs after 500 miles when running across studs, my big wheels on rear outer were ok that never saw studs. same thing goes for the all aluminum wheels that run over studs. inside the track run the BRP ones or kimpex same size... not cat or yamaha, they delaminate in one ride, ive also had a set of Tricked Out Toys aluminum with rubber inserts last over 5000 miles no issues.
That was there first batch 2 or 3 years ago. Thoses were replaces if the customer had any issues. There has been no problems since.all my JT wheels turned into stop signs after 500 miles when running across studs, my big wheels on rear outer were ok that never saw studs. same thing goes for the all aluminum wheels that run over studs. inside the track run the BRP ones or kimpex same size... not cat or yamaha, they delaminate in one ride, ive also had a set of Tricked Out Toys aluminum with rubber inserts last over 5000 miles no issues.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
they sent last year, i didnt even bother sending them back. still have on bench.
Still have most wheel kits on hand. Hope summer is short this year!Aberfoyle Power Sports in Ontario Canada is a distributor for J&T Products Wheel kits!! J&T is the number one seller by far of premium heavy duty wheel kits! Aberfoyle power sports in Ontariovand new has all the wheel kits for all the Cats all the way back to the Firecat days. kits for the Yamaha Vipers, Sidewinders and the new turbo Riot in house !! Aberfoyle now has the small idlers with larger bearings. The 5.5 super duty idler wheel replacements in STOCK right now!
Fast
- Sep 25, 2018
Tod said the 19 and newer can only fit 8.2" wheel kit but Hurricane is selling 8.5"You would need to contact them. I am in the states.
I'm measuring 1" between the shaft and stock 8" wheel so looks like 8.5" will fit 19 and newer
I put 3500 miles on my 23 SRX with 8.5Tod said the 19 and newer can only fit 8.2" wheel kit but Hurricane is selling 8.5"
