Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
I need to add a 4th wheel kit to 03 RX-1 mountain. Where do I get one and what are the measurements for mounting it to the sid frame? How high do I mount it so that there is not to much pressure on the wheels and track?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
4th wheel kits are typically adding the 4th wheel to the rear axle.
Are you referring to marginal wheel kits to prevent slide wear?
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
Thanks for the reply. I am referring to the Marginal wheel kits to prevent slide wear. I have my sled setup for trail riding with ohlins shocks and 1.25 lug track.
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
I have these on both my rx1....you can get them from Yamaha they same for all machine,they have a flat spot that sits flush on the rail just use a sharpie to mark hole and drill
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
Thanks for the reply. Do you know what they are called, so I can tell them what I am looking for.I have these on both my rx1....you can get them from Yamaha they same for all machine,they have a flat spot that sits flush on the rail just use a sharpie to mark hole and drill
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
Yamaha Marginal snow wheel kit
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
Thank you very much, Huge help going to order one. Happy sleddingYamaha Marginal snow wheel kit
