mattyg1405
do the mounts come with bolts?grizztracks said:Grimm said:Here's a well laid out post on installing larger wheels on your sled: http://www.ty4stroke.com/viewtopic.php? ... idoo+mount
I just added the Polaris wheels with Ski doo mounts in the rear. The wheels came from MFG supply: http://www.mfgsupply.com/04-0531-20.html and the mount from Ebay: http://www.ebay.com/itm/180758980906?ss ... 1497.l2649 This an easy install with only a small modification to the mounts. Four wheels, mounts and hardware was just over $100. I havn't added wheels inside the rail yet but probably will eventually. If you're not comfortable buying the parts and doing it yourself contact SBM and they'll set you up.
washers?
so if i got the wheels, and order the mounts what else will i need to mount them ?
thanks alot i appreciate the help
