09nytro
APEX 06 said:grumpysanta said:puts a little extra stress on the slide rails.. my 2 cents
X2 I fell the same way, if hifax ware is a issue ice scratchers go a long way and only cost 40.00 bucks. I like the Yamaha spoke wheels are nice looking and only 24.00 buck etc.. from Port Yamaha![]()
It doesn't , I think you guys are over thinking it ....
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
09nytro said:APEX 06 said:grumpysanta said:puts a little extra stress on the slide rails.. my 2 cents
It doesn't , I think you guys are over thinking it ....![]()
Most likely but with that much on just the wheel mounts I fell the rails will fail sooner. A lot of Yamaha sled hifax issues come done to the Track being over tight.
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
ive ran hyperfax slides with ice scratchers and zero wheels for 2 years now. if I still had the yamaha suspension under there I would be trying out the special yamaha slides the same way. since they are half the price of hyperfax.
the hyperfax slides make the rear end feel like its on butter. seriously... the difference between regular hyfax and these are a night and day difference.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
That and Yamaha use a very poor aluminum for the rails. There is pics of the rails cracking and the wheel mounts on TY some where if I could fine them. Both of my Apex's ran with stock Yamaha wheels my wife nytro and now my nytro xtx will have the stock wheel under it.
09nytro
grumpysanta
yes everybody is different , but check out the cost of new rails ,, i go with the ice scratchers they work great..
korgull
- Dec 5, 2012
- Canada, Québec
- Yamaha Nytro xtx 2010
ice scratcher are shure less expensive than excel 280$ or scmidth full kitt with the 4th whell at 485$
but when I look at a 135 wheel and a 130 one the difference is so little its hard to believe that it saves the hyfax or crack the rails, the difference is so smal betwen the wheels.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
slydog wheels worked good for my RTX
09nytro
You ask for people's option , so we who ave used the sheet kits told you how well or awesome they work and now you are going to question that , why ask then , I will say this before wheels 200 to 300 miles top after over 2800 miles , so like I said they work great and won't crack the rails at lest they didn't on my sled ......
Schmidt Bros wheel kits are Polaris wheels and you can get them aftermarket way cheaper then they sell them for , like half the price
I use to ride Polaris so I have a lot of those wheels
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
I have run excel 135.8mm wheel kit for 3 seasons (over 6000-8000 kms) now with no issues change bearings in them every year. pioneer performance also has a kit but uses stock wheels but moves wheels down lower on the skid 2.5mm to achieve the same outcome.
either way you will have to buy all new wheels for skid as bearings are not removable from the stock wheels in '09 (at least the one's that came on mine.....might be a Canada thing though???)
I usually run 3000-4000 kms a year and slides (Yamaha high performance, not even the DuPont ones) always look good at end of the yea, never changed a set of slides mid season so far.
I am going to try the pioneer performance kit this year as the excel kit doesn't look like it wants to work with timbersled suspension kit I have for this year. almost all the stock wheel locations were removed / bad locations with the new linkage kit.
cheers......
just my opinion
cheers......
just my opinion
korgull
- Dec 5, 2012
- Canada, Québec
Thanks for the info.
I will go for the easiest solution the excel 8 wheels kit they can be brought directly from. Them, all the other vendor of these wheels are out of stock.
Tyloooor
I run Polaris wheels on my sled and they work great!
shadow44
Tyloooor said:I run Polaris wheels on my sled and they work great!
do they bolt directly onto the Yamaha mounts or do they require any mods?
