Adding weight to stock clutching
04yamaharx-1
Sheboygan, WI
Ok, so I put on a Yosh.. I love it but now I'm hitting the rev limiter...bad. I've always avoided doing my own clutching because of how involved it is but I was just wondering if someone could tell me how hard it is to add weight to the primary on a stock clutch? And how much? Any help is greatly appreciated!
your better off to get a set of aftermarket adj weights,with the stock weights its a pain to grind out rivets and hammer new ones in...with aftermarket its as simple as adding washers..and it can be done without removing the weights from the sled
Or.......get a set of dalton weights based on the good old 8dns and you don't even have to take them out to add weight....Clutching is easy when you understand the principles and a LOT of fun when you see the results
...........02 :yam:
