snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I'm starting this year gearing up to 22t on top and sticking with dalton clutching. (37/35 helix) Running a viper primary and mostly the 300hp tune. I expect that to be a bit faster than the stock gearing. That said I bought cat gears and plan to switch over mid year to see how they compare. I'd like to change clutching at that time as well. Not looking for this setup to be the fastest... just as snappy as possible. You can find most clutch setups used right now so I'd pick up a set if anyone thinks one setup is more snappy than the next. I do have a 33/35 helix from Thunder products I never used. I see Bill Mohr uses a reverse angle helix as well. Not sure if that is really the way to go or not. Not sure what helix Ulmer is using. Thoughts?
Fleecer
- Jun 13, 2014
- 2019 SRX
Here is my 5 cents in response to your quest...
Gearing up to a 22t will make you faster everywhere, but will cost you some snap or the quick response your after. The lower initial angle 33/35 will offer better response, as the shallower helix will spool/light up faster. Adding more tension/stiffer spring in secondary will yield better backshift, spool up, and snap. Bigger rollers in the primary will also improve snap, spool up, but will provide less belt grip. This may be ok with lower gears, but taller gears will introduce belt slip and more heat in the clutches.
Just my opinion.
Just my opinion.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I hadn't thought about changing the rollers. I'm running the dalton B/O @ 90 currently in the secondary with good results. I am wondering if there is a better weight profile for a snappier setup than the Daltons. Also wondering if a larger reverse angle would be better or maybe that 33/35 is ideal. That would be nice since I already have it.
If you are looking for corner to corner improvements, why gear up?
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I’m just starting the year geared up to see if it is faster. Then I’ll change to the lower cat gearing and I’d like to see how snappy it can be and not worry about how fast it is overall. Which ever setup I like better I’ll keep.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I can say a lower helix is NOT going to spoil faster or shift faster. A higher helix like 39-45 straight is what you want corner to corner.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Which 300hp tune?
I run hurricane 300hp super spool header tune with wide band 02 module.
This tune is a rocket corner to corner.
For me its more like gas it off the corner and half way down the straight to the next corner let off so you can make it thru the next corner.
I would recommend a call to Thunder products clutching for your setup. They have helped me out.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I’m running the hurricane ss tunes. I do have a 38 straight dalton helix as well.
- 19K
