Kascade
- Jan 23, 2022
- PNW
- 2015 Viper MTX 162 SE
2016 Cat M8000 162 Ltd
As I've been using my sled a lot to carry skis and, in one case, overnight gear, I'm looking for a quick way to adjust the rear end a bit stiffer /higher riding when i'm carrying extra weight. It seems to sag a bit more than I would think it should. Are there adjustments I can make short of actually replacing springs or other components? I added some pressure to the rear shock but that doesn't seem to do a whole lot. Would adjusting the spring tension on the front skid frame arm shock accomplish this? Just trying to get some direction before I start in hard with trial and error.
thanks!
thanks!
Kascade
- Jan 23, 2022
- PNW
Sorry for the self-bump, but anybody have thoughts on this, or will I need to get a stiffer rear spring?
Mtnviper
Vendor
If you have a Float (air shock) on the rear, normally just adding air pressure will do the trick. It's what I have done in the past when riding two up. If your rear shock has a spring, you can increase the spring preload.
The front skid shock doesn't make a huge difference in load carrying capacity. It's main function is control weight transfer and has an effect on ski pressure as well.
Kascade
- Jan 23, 2022
- PNW
It's a float shock. I bumped up the pressure and it still seems to sit quite low when carrying a bit of extra load. I'll try adding some more.
DS22-HuberWoodsME
- Dec 5, 2020
- Easton Maine
- 2015 SR VIPER MT-X W/MPI TURBO. 153”
Maybe your shock needs a rebuild if it is not changing stiffness with added pressure.It's a float shock. I bumped up the pressure and it still seems to sit quite low when carrying a bit of extra load. I'll try adding some more.
Kascade
- Jan 23, 2022
- PNW
Turns out shock was fine, the pump just had something stuck in it so it was leaking pressure back out. Fixed it and stiffens up nicely now.Maybe your shock needs a rebuild if it is not changing stiffness with added pressure.
