adjusting the comtrol rod
Laubry
WATERFORD MI
sr viper
YAHOO
larryaubry@ymail.com
weight transfer max to min
max is more weight to track ?
I have it std now
Correct! I run mine on the Attak slightly, like 2 turns, towards minimum. Really helped with ski lift when exiting corners.
Careful adjusting!!!!!!!!!!! Many people on this site have adjusted incorrectly, very easy to do, which has caused the rod to break apart tearing the inside of the track and of course destroying the transfer rod. A very expensive fix.
They didn't nessarily adjust wrong, They just didn't tighten properly, or they went beyond the limits. the biggy is, make sure its tight!! Someone on this site had an upgrade last year for this part. They took apart and installed an o-ring inside to get rid of the clunking when going slow through a bumpy area. Have not tried this myself,so don't know how it all worked out. Good luck. Thinkin SNOW!! Honk
