Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
I can't find the magic tool to adjust and measure the transfer rod
Does anyone have the measurements for threads showing for min and max transfer?
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
No one?
HABS 1
- Oct 22, 2015
- corunna,ontario
mine is set at max and and then a little more! i took it apart and felt u could safly run a little more than the gage said without tearing out threads! anyway mine measures about 2 1/8 inches inbetween the 2 nuts , minimum transfer is about 3/4 inch less than that
HABS 1
- Oct 22, 2015
- corunna,ontario
HABS 1
- Oct 22, 2015
- corunna,ontario
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Awesome thanks!!!!!!
HABS 1
- Oct 22, 2015
- corunna,ontario
no problem
Maine Attak
- Jan 29, 2017
- Maine
- 2007 Yamaha Attak
Sooo? max = more ski lift? I want the skis planted!
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
Min keeps the skis down
HighSpeedLowDrag
You need the measurements for the 2010 and newer transfer rod. The 2005-2009 models are different.
I don't have the wrench or measurements for my 2010 either.
HABS 1
- Oct 22, 2015
- corunna,ontario
max is more ski lift , i got all i can, hammer it moving already and it lifts skis everytime bout, 6-8 inches ! i love it , just adds to fun factor!
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Better over the bumps with max transfer. Let's you modulate steering under acceleration too.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Yes but yo can't steer when on the throttle! Hard to steer when the skis aren't on the ground.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
I don't mean wot..lol.....you know, on fast trails around 60+, a little fuel lightens it up, and less sets it down. I just went through the whole rear putting new slides, a few new bearings (a little loose after greasing) in the upper idlers and I put rubber shims in the transfer rod (monoshock) which softens that clunk on slow stutters. Then set it about 1/16 from max. transfer. Hard to believe it is in as good shape as it is with the way we pound them on tug. It was reinforced and powdered by welter years ago. Pre Daytona checkup...lol.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
HighSpeed when you get the measurements etch them into your pry bar as you always seam to have that tool on your sled. Haha!You need the measurements for the 2010 and newer transfer rod. The 2005-2009 models are different.
