2008 Nytro RTX
Manul says to put a scale on of 20 lbs of pressure,This is all fine. Says if its wrong Put the snowmbile on a stand and take the rear axle nut off,Which is shown in the pic(Back idler wheel) Then says start the motor and turn it twice and shut it off. Then adjust the track left to right,I dont want to adjust the track left to right...Its lose! This is the way to do it or no?
2008 Nytro RTX
Come on guys,Please help!
Mikey
If you tighten up both bolts equally it will tighten the track. If you adjust one more than the other then it will move the track to the left or to the right off center. If your track is centered properly then you must tighten the bolts equally until the desired tension is attained.
2008 Nytro RTX
Since I do not have a scale is it possible to do it with out it and adjust it right??
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
14mm deep wall socket through track window at rear of sled........adjusting bolts are horizontal & pointing straight to the rear........tighten both sides evenly.....spin track with the motor & make sure it's centered on hyfax.
parkindale
Is it ratcheting/jumping? if not dont bother tightening it. I only ever tighten mine if & when it ratchets.
2008 Nytro RTX
Yes,Its Ratchening
Goddo
See this thread
http://www.ty4stroke.com/viewtopic.php? ... ht=#455232
I posted the two pages from the service manual...
walshie
I talked to my dealer about this because when I was first getting the ratcheting I was not anywhere near a proper scale. He told me to just make sure that I did the adjustment in small (1/2 turn) adjustments until it stopped. The key thing is to make sure that you tighten each side exactly the same because if you don't it will throw off the track alignment. Long story short: If you don't have a scale just adjust it in baby steps until it stops ratcheting. Don't go crazy though or it will make your track too tight and melt down you sliders a little sooner then you would like.
snownutz
Did you pull the front limiter strap up at all?
2008 Nytro RTX
No,Its stock. Why?
snownutz
Pulling it up a little will usually help prevent racheting.
2008 Nytro RTX
How many holes? What will this effect?
snownutz
1 or 2, it will take some of the weight transfer away, It will put a little more weight on the ski's. I don't know about yours but it seems like everyone else has way to much weight transfer with the stock set up.
2008 Nytro RTX
Is it going to make the turning any harder? Because this thing is very hard to turn!
