Iceman57
I have to replace my TPS and the manual doesn't cover the TPS adjustment. Does anyone know the procedure? Any help would be appreciated.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Here ya go. I had to replace mine last season....
http://www.ty4stroke.com/viewtopic.php? ... hlight=tps
Iceman57
1CrazySledder said:Here ya go. I had to replace mine last season....
I'm not familire on how to use the dash to adjust the TPS, could you walk me through it?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
-Turn the main switch to "OFF" and set the engine kill switch to "ON".
-Simultaneously press and hold the "SELECT" and "RESET" buttons for 8 sec.
-After selecting "dl", Simultaneously press and hold "SELECT and "RESET" for 2 or more seconds.
You use the "SELECT" and "RESET" buttons to advance or go back through the code number. They are 01 through 70.
TPS is 01.
Get the sensor in a spot where it looks close and use the throttle to see the value. You may have to move the sensor a little to match the correct value.
No throttle: 16%
Full throttle: 96%
Tighten up the two bolts, Turn the main switch to "OFF" to cancel this and put the gauge back to normal operation.
TPS is 01.
No throttle: 16%
Full throttle: 96%
Iceman57
1CrazySledder said:-Turn the main switch to "OFF" and set the engine kill switch to "ON".
TPS is 01.
No throttle: 16%
Full throttle: 96%
Thanx........Much appreciated
Renaud
- Dec 3, 2024
- Gaspé
- Apex 2009 gt lt-x
This proc edure is good for apex?2009-Turn the main switch to "OFF" and set the engine kill switch to "ON".
TPS is 01.
No throttle: 16%
Full throttle: 96%
