snowxwi
Ok, so I am trying to find a way to cover the 8 bolts (4 on each ski) that hold the carbide to the ski. I don't have a covered trailer yet, will be getting one next summer 2013. When I take the sled out snow/ice and eventually water get in those ski holes where the carbide bolts sit and it rusts over time.
I thought about using sprayable rubber on them, didn't work.
I don't want it to be super ugly. Does anyone have any simple solutions to this small annoyance I have? Also has to be somewhat removable so I can change the carbides when needed. The ones I have on now are brand new bergstrom triples.
I spray mine with metal protector (amsoil) or equivilant before each trip. I also wash my sled after each trip. Zero rust!
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Try fluid film, it's a lithium base lubricant that is non water-soluble.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Same as the guys above, usually Rust Check, Krown or something similar does the trick for me, but I also bring my sled into the garage after every ride so it has a chance to dry thoroughly.
teamyamaha
Try anti seize on the threads and a engine vacuum cap that fits snug and tight. It should keep debris off your threads!
snowxwi
I appreciate the responses.
I will look into some of these products and try one of them. I will also be bringing the sled into the garage after each trip/ride so it will be able to dry out. Shouldn't really be a problem but I thought there would be something simple to coat these/cover these with.
Thanks again.
Thanks again.
