yamadog07
can anyone give some input on converting a 2006 apex to a 136" set-up ?
is it best to buy a used suspension or is there conversion kits out there ?
how about the tunnel extension, have standard rear cooler for a 121", can this be re-usesd and does tunnel have to be extended ?
machzrobbie
Tracks USA makes a very nice set of rail extensions and there are a couple different tunnel extensions out there. I believe Ulmer has a complete set up to extend to 136 on his web site. There's a set of used rail extensions listed in the classifieds right now.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Muffin Works can provide you with the tunnel extension and rail extensions. We have both available at very competative prices ... And to my knowlege, we are the only ones that offer the tunnel extension with powder coating if you want. If you search around you will find that many have used our products, and we have an excellent reputation.
grader
i have the muffin works tunnel extension on my rx1, top quality product, perfect fit, zero issues.
Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
tunnel extension
I just done the exact extension on my Apex...I bought the tunnel and rail extension from Muffin Works.....Excellent kit...Excellent price...Excellent to deal with.....I went with the 121-136....My buddy here (phazernut)...Just bought the 144 kit off them a while ago...We did the extension on his Apex using Muffin gear..Again Great quality..!!!!....Call them......
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I used hartmann parts and love it. I made mean a 144" and love how it runs.
Newfie Apex
- Mar 3, 2010
- 2008 Nytro
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
And mine. All muffinworks extension gear. Great stuff and excellent customer service. Mine went from 121 to 144.
To answer your questions...I believe you can do a 128 extension without doing the tunnel. Anything over that and you have to extend the tunnel. The stock cooler should be fine. I'll be putting a set of ice scratchers on mine for extra insurance.
yamadog07
anybody running the extension kit with supercharger ?
any worries with extra torque / power ?
so i assume all other parts of my existing suspension including rear axle are still being used, just extending rails ?
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
yamadog07 said:So i assume all other parts of my existing suspension including rear axle are still being used, just extending rails ?
Correct
Maurizio Benelli
Have any of you had any problems extending 121 to 144? No need to move the skid backwards etc.?
I´m talking about stock mono skid.
Newfie Apex
- Mar 3, 2010
- 2008 Nytro
extension
Yup that is right...Pull the skid from the sled...Remove the rear axle...put the rail extension in place...very snug fit! drill the holes in your rails...bolt holes are already drilled in extension...bolt it up ..assemble rear axle and you are ..."Bob's your uncle"
Newfie Apex
- Mar 3, 2010
- 2008 Nytro
extension
When we did Phazernuts 40th anniverasry we left the skid in the stock location..Everything worked out fine..Mine when i had it apart I took out the mono shock and move the clip up to the top position....Now at the softest setting she just barely settles....
