rx1mountain
Hey guys I picked up a 03 RX1Mountain with a Bender Stage 2 rear mount and have had it out twice now and I am almost afraid to hold it wide open for a long pull. My A/F is in the 11's at WOT am I just being paranoid ? It is a crazy amount of power that is for sure and I am only running 10LBS of boost !
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
hahaha you gotta love boost, wait till you upgrade it to run 18+ lbs ....
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
rx1mountain said:Hey guys I picked up a 03 RX1Mountain with a Bender Stage 2 rear mount and have had it out twice now and I am almost afraid to hold it wide open for a long pull. My A/F is in the 11's at WOT am I just being paranoid ? It is a crazy amount of power that is for sure and I am only running 10LBS of boost !
Keep a Close Eye on the Water Temps, you may want to add some additional cooling if not already done.
HP Makes Heat, you need to get rid of it as fast or faster than you make it or something will melt.
Ted.
rx1mountain
Ted.
It has an MPI tunnel with a rear heat exchanger. Any other cooling recommendations?
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Kinda like this...
http://www.youtube.com/watch?v=WF1FSS05rYc
Listen to Ted on this one - long pulls with boost will very quickly identify any weakness in your tune in the most of expensive ways.
BenderSRX
- Nov 29, 2006
- Constance Bay Ontario ( Ottawa )
- 2013 Yamaha Nytro RTX
Ted Jannetty said:rx1mountain said:Hey guys I picked up a 03 RX1Mountain with a Bender Stage 2 rear mount and have had it out twice now and I am almost afraid to hold it wide open for a long pull. My A/F is in the 11's at WOT am I just being paranoid ? It is a crazy amount of power that is for sure and I am only running 10LBS of boost !
Ted.
Ted what would you consider high water temps? or when to let off. Mine when just crusing around is at about 165F then i do short blasts. We do not have anything long enough yet to hold the throttle WO until the ice is good. Just so i know when to let off
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
BenderSRX said:Ted Jannetty said:rx1mountain said:Hey guys I picked up a 03 RX1Mountain with a Bender Stage 2 rear mount and have had it out twice now and I am almost afraid to hold it wide open for a long pull. My A/F is in the 11's at WOT am I just being paranoid ? It is a crazy amount of power that is for sure and I am only running 10LBS of boost !
Ted.
I have seen several issues with Temp guage installations, If the Sender is not properly grounded the guage can be way off.
I thought I should mention that because I seen it so many times, guys will put the sender in a rubber hose with a T fitting, not knowing it needs an engine ground to work right.
I like 185-190 Max under WOT.
Location is also very important also, it must be in the hottest part of the cooling system.
Mine is in the Stock location on the T-Stat housing with a Ground Wire attatched.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Ted,
Awesome tip!
Awesome tip!
is it any treads that describe the A/F values and what "good" values are??
rx1mountain
I have read that 11's or high 10's is good maybe even low 12's at WOT I try to keep mine in the 11's for a happy medium.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Cilius66 said:is it any treads that describe the A/F values and what "good" values are??
Idle or Very Light Throttle 13.5-14.5
Moderate accleration 12.5-13.5
WOT 11.5-12.0
Skydog
Ted Jannetty said:Cilius66 said:is it any treads that describe the A/F values and what "good" values are??
WOT 11.5-12.0
NICE NICE INFO AGAIN FROM TED!!!
Skydog
tonykof
rx1mountain said:Keep a Close Eye on the Water Temps, you may want to add some additional cooling if not already done.
Ted.
rx1mountain,
I know that sled well, you are good on the cooling. I would leave the jetting where it is for now as long as it's not blubbering I believe at about 1000 feet elev that sled is presently jetted for about 12psi so it may be a little rich at 10psi. Don't worry, you'll get more comfortable with the boost... sorta....
rx1mountain
rx1mountain,
I know that sled well, you are good on the cooling. I would leave the jetting where it is for now as long as it's not blubbering I believe at about 1000 feet elev that sled is presently jetted for about 12psi so it may be a little rich at 10psi. Don't worry, you'll get more comfortable with the boost... sorta....![]()
Tony,
I had it out last night and did get a little "blubbering" towards the end of my ride. I am going to dial up the boost a couple pounds and see how it does. It was running around 10.9 at WOT on the A/F so I might play with the pitot jet and get it closer to 11.5. Man can this thing dig a trench and keep on going !!
