racecar
Suspended
- Dec 22, 2016
- Zr9000
Do all flashes and others raise the parameters on the knock sensor rpm and other map rpm. Basically what I am asking is if rpm limit is raised if possible, are the other max Rpms raised also. In the early years with the suzk ecu the knock sensor was disabled after 8350 or 8400 rpm but max rpm was raised to 9000 therefor after 8400 the knock sensor was not working.
