snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
my son just blew out the rear shock on his standard 07 phazer, does anyone know of any aftermarket ones? where can i find them, tried dennis kirk and no luck,
If you can afford it get a Custom Axis.Otherwise is some options including Ohlins.Maybe he will speak up but I know there is someone here running rear suspension shocks off a SkiDoo ZX chassis.If really desperate I do have a stock nonrebuildable steel shock but it really is a piece of junk as far as ride quality.Also be sure the problem isnt the link front and rear shock go to.
RoicIND
They're actually form a ZX chassis and in the 700 miles I've done in the past two weeks using this set up, I am simply enamored with how it's transformed my FX. If anyone is interested, PM me and I'll give you my set up for a 190# rider.... Back to back, my Phazer is out performing my set up REV in the stutters and in the big bumps..
Thanks for outing me Cannondale!!!
My pleasure!I am going to try one of those in the center position.Thanks for tip.
snomaniac
schmidt bros has fox zero pro's they sell. That's a pretty good shock from what I hear. I'm running walker evans from an 08 dragon rmk in mine, and they work well. ( slight bushing mod, and the center shock is shorter than stock so it lowers ride height.) Get measurements from your stock shocks then look around on the sites something will turn up.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
I am runnign fox shocks and they realy work well. Piggyback center shock
