Aftermarket Temp Sensor location in T-Stat housing?
edge_232
Madison WI
2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
I was told by a reliable source you can drill and tap an aftermarket temp sensor into your stock Nytro T-stat housing. You just drill out the center of passageway in the pictured casting boss and then tap it for your sensor (see picture). Has anyone else done this and how did it work?
