edge_232
- Jan 15, 2014
- Madison WI
- 2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
I was told by a reliable source you can drill and tap an aftermarket temp sensor into your stock Nytro T-stat housing. You just drill out the center of passageway in the pictured casting boss and then tap it for your sensor (see picture). Has anyone else done this and how did it work?
Sportsterdanne
edge_232
- Jan 15, 2014
- Madison WI
Cool! Thanks for the post and I'll be sure to add it to my build write up.
MNnytroturbo
- Nov 5, 2013
- Iron Range, MN
- 2011 yamaha nytro xtx 162"x2.5" , push turbo, mountaintech full skid plate,OFT roll over valve with tether, OFT steering relocater, Avid drivers, Rox 3" riser, timbersled front bumper, mtn air skid, roest dash vent, koso x2 guage, Scmidtt brothers clutching, homemade manual fan control for cooling underwood temps and more I can't remember
I did this also! Much better than cutting up a coolant hose and adding a t- fitting.
