Aftermarket tunnels for Mtn. Vector?
ACG
Salt Lake
Hartman Performance makes a great looking, sturdy extension. I have got one on my sled. Only set back is it looks like the extension wont go forward along the tunnel as far as that wrinkle is. You can take a look. MPI makes one aswell but it looks a little more squared off and the grab bar is kinda ugly. the harman extensioin runs you abou $200 and saves some weight. that wrinkle further forward in the tunnel can be taken out with a block of wood and a hammer when you put the extension on. You wont even be able to tell it was there. Just be gentle. good luck with the sled.
www.hartmaninc.com
www.mountainperformance.com
this is extreem but a option van amberg tunnel
If you go with a tunnel extension.I recommend the hartman I like the looks better then mpi and they seem to be buildt stronger.
