Air bleed 2012 SE
steiner
Staff member
Moderator
Niverville MB Canada
Installed a coolant heater on a 2012 SE. Looking for the air bleed screw. Instruction state to remove 4 bolts that hold the hose cover.
I can't see that working because the rear cooler is past the rear of the seat and exhaust cover.
Any tricks on bleeding the system besides removing one rear hose while filling the system?
Never mind. If you take the left side cover off the screw is there. Its not under the right side and of course that the one I removed first. :o|
