powershot1
I've been working on air flow thru the intercooler.I've added a scoop to the hood .and foam to the bottom of the scoop to direct air through the intercooler.I also added foam to the clutch side to keep snow from getting on the clutch.
I also found in testing that you must roll or concave the back edge of the foam to direct the air into the intercooler. a square edge does not work.
I must have 10 hours into this project I have also installed thermal coupler into the heat exchanger so I can see the Delta across the cooler.
powershot1
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
powershot1
helmic
- Nov 10, 2008
scoop
I would like to see it when its done and on the sled.
powershot1
powershot1
helmic
- Nov 10, 2008
