Air Fuel Ratio For Naturally Asperated Apex
Today, I learned that my stock Apex, can out pull my buddies stock 07 F1000 from a 50 mph roll on to well over a 100mph. I looked down and I was doing 115mph on the DM and I let off because for one, I was on a groomed trail and two I just kept pulling on him.
hey rtx meirda.....how are you reading the air/fuel mixture ?im curious because i would like to try similar test that you did,let me know,if the reading went up to 12.6 from 12.1,the air holes are really showing a difference,the holes actually leaned the mixture aout 1/2 a point,thats quite a bit,the efi adjust wot by the air box air temp so at -8c that would be about 16f,i would like to try it at a few different temps just to see if it actually makes a big adjustment to compensate for temp changes
I installed the same wideband o2 sensor as 87GTNOS. NGK makes the unit.
I don't think temperature is doing much to the mixture.....but i will know for sure later.
12.1 is a richer mixture than 12.6. I would like to try a ram air lid as well just to see.
If you guys want a brand new boondocker efi control box to fine tune with i got one for $400 cdn.
:bump: for my own reference. Don't have a O2 sensor installed or access to a dyno locally, but might hook my Apex up to the exhaust anylizer later today.
Here is my one handed A/F gauge video....it's really not that clear and doesn't really give you the 'jist' of it all. Holding on to the sled with one hand you can't hold the throttle steady!!
http://media.putfile.com/AF-gauge-vid
