DelgatyXTX
I noticed that after I installed my filters, the wire that plugs into the sensor in the airbox has no place to go. Will it be ok just left unplugged or will the sled throw a code?
Thanks,
Ryan
Thanks,
Ryan
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Leave it plugged in but secure it to something so it's not loose. I zip tied mine to a support post.
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
I drilled a small hole towards the front of the radiator shroud and zip tied mine to that.
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
ziptied mine to the main harness plugs and put the rubber harness cover over it.
DelgatyXTX
OK, good to know. Thanks guys! I thought if it wasn't picking anything up it might cause an error of some sort.
macnytro
- Nov 24, 2008
i did this to mine & spring riding it ran like crap because it was getting to hot, so i moved it to the radiator shroud on the outside & not a problem after thatnatedawgedog said:ziptied mine to the main harness plugs and put the rubber harness cover over it.
natedawgedog
- Feb 5, 2011
- DLG, Ak
macnytro said:i did this to mine & spring riding it ran like crap because it was getting to hot, so i moved it to the radiator shroud on the outside & not a problem after thatnatedawgedog said:ziptied mine to the main harness plugs and put the rubber harness cover over it.
i never had a problem with it last season and most of my miles was in the spring/very early summer riding. I dont know if that had anything to do with the pc5/autotune doing its job to keep the engine in the right zone or what but it worked, and worked well
