Can I run with the air intake temp sensor code flashing.
Somehow I broke off a wire for the temp sensor.
I can't figure out how to remove the little clips from the coupler. I have to walk away from it before it gets to mangled to be reused.
I've also thought each time i've moved that sensor around.
Danm those wires are thin and kinda exposed.
I wonder how far back you can cut into the plastic before it becomes junk.
How do they come as a new part P/N 8FP-85886-00-00
Wires fixed? Or do leads need be shoved down in the holes?
I actually got a used coupler from Mod Fathers today. He left 3-4 inches of wire on the coupler so I can soldier it.
Scott has a few chopped up Yamaha harness laying around. He gave me the coupler for free.
You should see the Nytros and Apexes he has in the shop. There is more then a half dozen boosted sleds there. I had no idea they were that big into yamahas.
