Blue shadow
today I went to 22 psi
on 660 ft . This was the fastest ride I ever went for .A/f at 12.1
Some times at take off she would hit 18 psi and then drop to 12 psi with in 50 ft
.Between each run I would let It cool down to 120 degrees and start again ,then the next run she would be fine again .It keeps doing this between runs .I put a new set of plugs in and the same thing.Could it be the wireing that is doing this ?
.Between each run I would let It cool down to 120 degrees and start again ,then the next run she would be fine again .It keeps doing this between runs .I put a new set of plugs in and the same thing.Could it be the wireing that is doing this ?Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Blue shadow said:today I went to 22 psion 660 ft . This was the fastest ride I ever went for .A/f at 12.1
We need more info.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
What kind of boost controller do you run and where does your A/F go when this happens?
Do a boost leak test.
Blue shadow
One of the wires was bad on the coil ,all fix now ,thanks
