Triplerev
Is it making boost when you keep the waste gate open?
Blue shadow
no,can not make boost on a stand,I never seen it before ,thanks
Blue shadow
Went over every thing and could not fine anything to help it stop after firing from the exhaust.When the wastgate is open its fine from 0 to 10000rpm and when close it does it again at 4000 rpm and will not climb.Dave hurricane when I remove the intercooler it does the same thing with the wastgate open or close ,it will not clime over 4000 rpm.thanks .Do any body have any ideas of what is going on?Been 6 days today and no luck.
Blue shadow
Just put a another stator plate in and still the same .I just remove the exhaust header to take a look at each exhaust port when at idle and there is more of a flame coming out of # 1 .Also the colour is orange when looking inside the port.On #2,#3,#4 cly s the colours are blue when looking inside the ports .What is causing this .Its not the spark plugs or the coils because I change them and still the same when looking at the exhaust ports on # 1 side.thanks
Blue shadow
Just found the problem .The pilot tube was block off in the middle and could not get the right air to the float bolws.Back to normal again.Thanks to Dave Hurricane for taking the time with me on the phone and leading me in the right direction.Time to start testing again.
rx1 fern
glad to hear you got it running .i am almost done with my msd install too.i am waiting for my map senser and my momentary switch which should be in any day now.should be testing mine this weekend.talked to ted jennetty today and he is going to help me out with some files for my box.i might try 22 pounds of boost on her with some timing on her.i will let you know how it turns out mike .it is good that yours is running now.
Blue shadow
I will give you a call next week ,thanks
