im thinking of getting rid of my rear mount bender setup on my apex. what is the hp rating of the alpine kit? can u use factory headlamps with their kit?
It depends on what turbo you run with the Alpine kit. I have run 22lbs of boost with mine = 360 H.P. or some where in there. Stock head lights you should call Dean he will help you in that area. There is alot of heat around the turbo and you want to be able to cool it under the hood. Alot of guys run after market lights and keep it open for more fresh air cooling the turbo.
