RdKingRdr
- Dec 2, 2024
- Pa
- 2006 Yamaha Apex RTX
Hey folks, I just acquired a 2006 Apex that has been sitting for a couple years due to it needing the muffler replaced after a prior cobb job. I've got it disassembled to where I can do the work but a question I've got is if anyone knows the best cleaner/brightener of oxidized aluminum? Thanks
mothers is what a lot of guys use.
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1981 ET340 "Frankenticer"
1982 SS540
1981 ET250 Mod Oval/Lemans Racer
Mothers and a powerball.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
And if you need to get it like a mirror, resort to wet sanding it. It's pretty amazing what you can do with raw aluminum and 1000/1500/2000 grit sandpaper. Then as the others have said, mothers and a powerball. Or your fingertips and rag. But they will be sore, it's rewarding, but not easy on the fingertips.
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
I concur with the wet sanding and then White Diamond Metal Polish...stocked at O'Reilly Auto Parts here
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
Here is an old video I did, and have shared here before. You may get a couple tips from it.
- 8K
