Question about replacing the a arm bushings
RtxViper
Deerfield, Wisconsin
2019 SRX LE
This is probably going to sound like a dumb question but I took my a arms out and had them powder coated. When i disassembled the sled the a arm bolts were loose in the holes. I figured this was due to the bushings being worn out. I replaced all the bushings and reassembled the front end tonite and go to tighten everything up and the bolts are still loose. They move front to back maybe an 1/8". I am assuming this is not supposed to be this way. Anyone every run into this? I am assuming I should just add a couple washers but just making sure that they arnt supposed to have play in them. Thanks in advance
I used stock replacements and i did reverse the rear ones. the a arms are nice and snug but the bolt itself moves back and forth 1/8" thats what i am concerned with. I used stock ones cause i plan on selling it at the end of the year
They will be fine,they have a little play in them. I'm sure tightening them up with aftermarket bushings like the other guys said would be nice but the way they are is fine.
Bushings
I have just finish installing 5 sets of Ulmer oilite bushings on four Venture and one Apex and there is some play on the bolts going back and fort about 1/8 to 1/4 inc.Its like that on the new sled just normal I guest.But why I couldn't tell you...
