happy1426
i got a 06 rtx with low miles and i want a put on a excell exhaust a ram air intake power commander and a clutch kit and # 10 plugs.. I Plan on buying everything from Ulmer Racing, just wonder if im going to have any bog or popping and slugish spots in the sled or any other problems im not going to be running to rich fouling up plugs and what not??? I have no one good around here with power commanders so i was just going to see if he could dial it all in for my mods before he sends it!! they are plug and play right!!
Ulmer sets up based on your sled. Since Ulmer is supplying everything, you should not have a problem. I can guarantee you when you call Allen to order, he will tell you to call with any questions/problems.
mr.pitstop
If you do experience any bogging issues you can adjust it in the co settings on your instrument pod. Ulmer will explain all of that to you when you buy im sure... Its easy to do and it is all adjustable.. I wouldn't worry about it, he will have you running prime..
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
Ulmer will look after you if you have any issues. He is second to none in customer service.
X2 Phazernut
With the PCIII, is there really any need to use the CO settings?mr.pitstop said:If you do experience any bogging issues you can adjust it in the co settings on your instrument pod. Ulmer will explain all of that to you when you buy im sure... Its easy to do and it is all adjustable.. I wouldn't worry about it, he will have you running prime..
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Carver said:With the PCIII, is there really any need to use the CO settings?mr.pitstop said:If you do experience any bogging issues you can adjust it in the co settings on your instrument pod. Ulmer will explain all of that to you when you buy im sure... Its easy to do and it is all adjustable.. I wouldn't worry about it, he will have you running prime..
Yeah, when you have the power commander no need to adjust CO settings. CO settings only adjust your fuel/air mixture at idle and just off idle. Power commander adjusts mixture through-out your entire rpm range.
sleddheadd
You can trust Ulmer! If it is wrong or you have problems just call him and he will make it right!
X2sleddheadd said:You can trust Ulmer! If it is wrong or you have problems just call him and he will make it right!
happy1426
ok thats decided then thanks guys!!
