Well heres the deal guys, i have done all the searches and need a some distinct answers here regarding the crankcase pressure vent. As others have been experiencing when I roll my 04 rx to the left, a bunch of oil ends up ruining my clean engine bay, belt plugs and bla bla bla. I understand the idea behind the running of the tube with the heated hose running inline to prevent freezing but I still need clarification on these questions.
This first question may be dumb but, is the pressure the crankcase is venting, air pressure or oil, i'm assuming air vent because of high oil pressure ??
If air pressure is venting could you not simply attach a small air filter to the hose, and fit it upright so that it can vent when needed but oil will not leak out if machine is tipped over?
Is there any fix to this leakage problem that is maintenence free that you can explain??
Does anyone have a picture or explicit description of where this hose is?
THANK YOU VERY MUCH for your time and patience, i'm still learning, hopefully this was the right forum.
If the longer hose fix works, where do you run the hose and does it simply have a plug at the end or does it just return to itself?
