Anti-freeze change
TJRTX
Wisconsin
Would like to know where the best spot to drain anti-freeze from moter. Do i remove hose from heat exchangers or is there a drain plug of some sort on moter. Thanks for any info.
Remove the hose on the right bottom side behind the chain case and lift the rear of the the sled,after remove the hose on the rear cooler or tube and lift the front of the sled,it should all drain out the system.
