Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Anybody have a good source for replacement shafts for anti-stab kits? It seems (faulty memory) that there was a good source for shafts of all sizes online somewhere. I just can't recall.
This shaft is no different (except for size) than many cross shafts.
I will post exact measurements tonight. But the shaft diameter is designed to fit a 5/8" bore bearing (6202 - 5/8" maybe). I have 15mm bearings that don't fit of course. The shaft I have is worn from spun bearings bad enough that a new 5/8" bearing just slops around on it.
I have also considered shimming the new bearings to keep them from spinning.
Any thoughts?
Any thoughts?
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Any reputable machinist could turn you one for cheap. I've made plenty of them for myself and friends. $5 worth of aluminum and about half hour's work is all it usually takes. Take your measurements or old shaft with you and get a quote.
sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
Whal Bros. should have them as well.
FLYBYU
high performance engineering
ahicks
A little late, but it just dawned on me what you were looking for. Another vote for High Perf.
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Actually Hi-Perf sells the whole kit for $90.
On the other hand Wahl Bros sells the bare shaft for around $10.
I chose the latter . . .
ahicks
They have the kits, like any of the others, but they also sell the components seperately. Glad you found what you were looking for.
- 15K
