Anti stab kit
offside
North sweden
Anyone know where to buy an anti stab kit. For a Yamaha apex year 2007, with monoshock bogie? Have found various shops that sell kits, but it says would not fit to monoshock bogie? Can someone clarify this for me, so I understand?
Thanks in advance. Tobias / Sweden
SLP and hiperf.com will both sell most/all components to make your own kit. I'm thinking the reason they don't supply one is because they aren't necessary? Just guessing though...
Wahl Bros makes them and you should be able to order direct for $90 USD. I have one in my mono.
Do you have any pictures on the installation? Then I look for a couple Wahlbros.
Has been in contact with Ken's Sports. He wrote back like this. But I think it's the wrong thing to mono shock bogie on my snowmobile. Do not know how they are, or how they should be. Need some help
-The One That You Need is part # 4702-0073. Since You Have a centered strap Limited, That Is The One That You Will Need.
http://www.kenssports.com/dlrindexsend_ ... L+KITS.htm
Mine look likes this
You need Wahl part number 02-790A. It simply goes in place of your front limiter strap shaft (shown in your picture). Pull the 2 bolts (1 is visible in the pic). Slide the center portion of the kit through the limiter and between the rails (you have to pry them apart a little with your hands). Then put an outer portion on either side and tighten up. I recommend using locktite. Very simple install.
The part Ken's recommended sounds like the right one.
Here is a pic, it is the top one. http://www.wahlracing.com/product.php?p ... ck=srclick
X2
My 2008 MTX has 2 limiter straps that would be in the way of where the anti stab roller wheels would be. Is there another options?
