red dog
I just bought a used Apex XTX with 4k miles on it. Been riding a 2007 standard Apex. Was wondering if there is anything I should look out for as compared to my 07?
I weigh about 280 lbs. and will be only trail riding, any advice on suspension settings ? I will be riding 2 up with a seat jack installed about 25% of the time. Wife weighs 130lbs. I would like to set the suspension up and leave it. I'm a fair weather rider. If the trails aren't nice I'm not riding. Not at all familiar with this skid any input would be great. Thanks
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Try it with the torsion springs on medium 1st. If it bottoms too much, try it on hard, solo riding.
There are 2 spring rates available for this sled. It seems the Canadian ones came with the higher rate springs as I had to order the soft ones as mine rides really stiff and I weigh in at 250 + gear.
As it is a used sled it should be set close unless the rider was smaller than you already.
bankershrs
- Sep 19, 2008
- Roscoe, IL
- 2017 Yamaha Sidewinder RTX LE
I made similar switch to '12 xtx this year. Run about same on weight. Have springs on medium setting, shock set 6 clicks out, stock setting on front strap, somewhat neutral setting for transfer. Works well for me. Sled rocks, enjoy!
Grimm
I've heard the 2011 XTX is very hard on sliders, wearing them out prematurely. Upgrading the size of the idler wheels should help alleviate this problem.
I got 2600 km out of the stock sliders on mine, witch was not too bad in my accounts. burnt a set off my 05 war in 500km in fresh powder till I got it set right. I have the oversize wheels on mine but I went with realcools and will see how long I get with this set-up.
yamman
2011 apex se
something you might want to check is exhaust donuts .changed mine today I barley could hear the leak at start up sled hatd 3800 miles .after warm up noise will stop. wanted to check exup today anyway a lot simpler than the last six apex I had after seat and tank is off 20 min and your done.
RtxViper
be careful a couple weeks ago i had to double ride a buddy that blew up his 800r and after bottoming out a quit a few times the pull rods broke which reeked havoc on other things so make sure u set it up for the extra weight
red dog
Thanks guys. Is there a place I can go and order all the idlers as a kit ?
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
red dog said:Thanks guys. Is there a place I can go and order all the idlers as a kit ?
Right here: http://www.ulmerracing.com/
Click on the "Accessories" link on the left side of the page and scroll down the page until you see the "X-Wheels".
They sell the oversize complete "X-Wheel" kit for your XTX. I've got them in my XTX skid along with the Dupont hyfax and that combo is perfect for minimal wear.
RtxViper
VX1R said:red dog said:Thanks guys. Is there a place I can go and order all the idlers as a kit ?
X2
