HighSpeedLowDrag
Steering linkage
ZapeX2
Yep, they go on the end of the bolts that hold the steering pivot assembly on. Low in the front nose of the sled. Really hard to see them but they are there just in case your bolts come loose, that they won't fall right out and have zero steering...
HABS 1
- Oct 22, 2015
- corunna,ontario
- 2006 apex gt,136 Hartman ext,dalton clutched,full excel exhaust,yamiheaters,cna pro ex white skis,hid lights,mtx riser,1.5 intense track,etc,etc!---2021 sidewinder xtx se
pull hood off , take off plastic cover hiding ecu ( 2 screws) by regulator, look in there u will see 2 bolt ends they go on there , fairly easy to put back on, might have to remove ecu, no big deal!!!
