hot rod rooster
- Jan 9, 2005
- saskatoon, saskatchewan, canada
- www.arrowheadcustoms.com
i am a believer in letting the secondary float about 1/4 inch on jack shaft. with the way the rx's jack shaft is held in place by the tappered colar if you let it float you run the risk of having the collar come out a bit and bugger things up.
has anyone cured this problem?
