1chopper
- Dec 19, 2005
Mine has 300 miles on it and it bogs when first hitting throttle mostly low rpms.Its not getting better.I think it doesnt have a enough fuel pressure But I do not know the specs.Its under warranty but there not a dealer ship around me where I would let them change my idler wheels.Just wondering if anybody has a fix yet.
sledheadgeorge
last time I ever herd a bog was about 4 years ago with my last 2-stroke. LOLOl
kviper
Mine had the same thing, Took it to the dealer where they set the EFI two click's richer and all is good so far. kviper
True Blue
Probably at the dealer.
Just kidding, probably something thedealer has to do?
TB
TB
1chopper
- Dec 19, 2005
The dealer in this area could not change the bad idler wheels without screwing them up.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Where do you set your fuel 2 clicks richer???
Silverbullet
This was just a "i heard" rumor but at the spring shows a dealer was showing me the new display and thought that some FI adjustments could be made with it. 8)
1chopper
- Dec 19, 2005
I went to the yamaha parts catalog online and found adjusting screws.I believe on metering block just on top of fuel injectors.2 say air metering and the other just says adjust screw so im going to play with it and see what happens.
kviper
They hooked it to the computer is all i can tell you. For somthing like that i would not screw it up. If it has a flat spot, Take it in and warranty should take care of it. kviper
X-APE
- Sep 13, 2005
I have the same bog, low rpm only. Its a bog that quickly goes away, more of a stumble. Waiting for other to become aware and find out what to do about it.
