DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I hope not, I upgraded to the anti-shim spitting buckets, high rpm valve springs and retainers.after those common chks, you may have spit a shim from valve
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Each time I have come across issues on popping on decal was from a exhaust leak pre turbo!( test it hot)
Diagnosis mode: key on hold both left and right bottom button on gauge for 10 seconds
As Marc said...here is a good link to TPS info
ty4stroke.com
Winder TPS(Throttle Position Sensor): Please chime in everyone
After watching Cannondale's video I was curious(bored)so I decided to check out all the functions on our stock factory WINDER Gauge. I was abit taken back to find that my TPS(Throttle Position Sensor) would only max out at 79.6 degrees when I held my throttle lever WOT as shown in video below...
ty4stroke.com
DMCTurbo
- Nov 12, 2005
Thanks everyone!
sledding rocks
- Feb 11, 2017
- north
- sidewinder
dmc . on my sled once i started it at idle it didnt sound right at all , a very small popping sound , once i put my hand around the bellow connector on the header u can feel the hot air pushing out threw the crack , i also went out and noticed quickly it wasnt making boost like it did before , spool was poor , which made the sled feel very lazy . my fix is easy , but expensive , not good if u cant get 1500 miles from a header ,
DMCTurbo
- Nov 12, 2005
I'm hoping it's as simple as that. Sure will be pissed if my headers cracked at 1500 kms.dmc . on my sled once i started it at idle it didnt sound right at all , a very small popping sound , once i put my hand around the bellow connector on the header u can feel the hot air pushing out threw the crack , i also went out and noticed quickly it wasnt making boost like it did before , spool was poor , which made the sled feel very lazy . my fix is easy , but expensive , not good if u cant get 1500 miles from a header ,
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
i want to replace my clamp on the header to turbo... does anyone know the size?
Fleecer
- Jun 13, 2014
- 2019 SRX
What's the fix?dmc . on my sled once i started it at idle it didnt sound right at all , a very small popping sound , once i put my hand around the bellow connector on the header u can feel the hot air pushing out threw the crack , i also went out and noticed quickly it wasnt making boost like it did before , spool was poor , which made the sled feel very lazy . my fix is easy , but expensive , not good if u cant get 1500 miles from a header ,
sledding rocks
- Feb 11, 2017
- north
- sidewinder
new headerWhat's the fix?
What header is on your sled?I'm hoping it's as simple as that. Sure will be pissed if my headers cracked at 1500 kms.
DMCTurbo
- Nov 12, 2005
TD GEN 1What header is on your sled?
Sounds like there are a few members that have had flex joint cracking issues on that header. Dave says the Hurricane header's internal joint still seals even if the flex joint should crack.TD GEN 1
see post number 77 in this thread
Tune differences
No, boost pressures should be very close. Power will likely come on sooner and harder and if your trying to attain bigger speeds of 125+ i think the pm will help there. The header tune will make same power at lower boost pressure. I believe 270 header pm tune runs around 15psi vs the 17-17.5 of...
ty4stroke.com
Isn't that the same as the factory? Doesn't it just prevent the leak from becoming major?Sounds like there are a few members that have had flex joint cracking issues on that header. Dave says the Hurricane header's internal joint still seals even if the flex joint should crack.
Tune differences
No, boost pressures should be very close. Power will likely come on sooner and harder and if your trying to attain bigger speeds of 125+ i think the pm will help there. The header tune will make same power at lower boost pressure. I believe 270 header pm tune runs around 15psi vs the 17-17.5 of...ty4stroke.com
I would say thats the case...but don't know for sure.Isn't that the same as the factory? Doesn't it just prevent the leak from becoming major?
DMCTurbo
- Nov 12, 2005
Did the glove over the exhaust trick with the engine cold and then warmed up and she snuffed out right away. No sign of exhaust leaks.
