ecopter
Just wondering what kind of job this is. It's under Tech Tips in the 2004 Technical Update Manual. It states that it's possible for coolant to leak from the o-rings between the coolant pipe and the carb. body.
Has anyone changed these and is it a pain in the arse? I had the carbs off tonight to change jets, but I have never seperated them from each other. It looks as if they must be seperated inorder to change these. Also, another Tech Tip specifies that care must be taken so as not to break the T-fitting for the fuel lines going to the carbs. If I must seperate the carbs., are the fuel lines easy to seperate from those fragile T-fittings?
Any advice?
Thanks,
Jon
Any advice?
Thanks,
Jon
