Just to clarify, this happened with a non-OEM center shock absorber with a very short and non-restrictive passage between the shock absorber body and the compression valve.Alatalo said:I cracked a center swingarm on my -08 RTX 40th, but not in the place you are talking about. My left side tube (connecting the upper tube and the left side rail) started to show a crack straight across the tube at the end of the season (approximately 5000 kilometers).
The shock absorber hose is obviously restrictive, but based on the input from the guy that started the thread, is this really his main problem...?stopdropanroll said:Change the shock hose! Call Leein at HyGear, he will tell all about that shock.
