number1kyster
My 07 RTX floor board radiators are starting to crack and leak. My sled has 13,000 miles on it and still two years left on the warranty. I'm going to see if I can get them replaced by warranty. Any one else have this happen?
DoktorC
Yep...mine cracked right under the rear drop bracket. I popped it off and had it welded...
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Yamaha give me to new ones one for the left and the right. this past fall.
NY AttakGT
^^^^What he said
Both sides cracked and were swapped under YES warranty.
--Steve (O.C.)
--Steve (O.C.)
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
Mine also. The left side last year (4,700 miles) and the right side this year (6,000 miles). The YES warranty covered them...
I was told if you stand up alot (which I do) it may be 'part' of the cause.
number1kyster
Mine are cracking right where the rear skid mounts to the tunnel.
Simmering25355
both mine cracked by the dropbracket 5500km new ones
replaced under warranty
Budweiser
Can someone put a pic up of where and what the cracks look like? My attak has almost 14,000 miles those cracks are a concern. I don't stand a lot though.....
srxtwins
Attacks are much less likely to crack due to the larger rear suspention mounts which spread the forces around the tunnel more. 21000k on mine and I am not worried. The issue seems to be most common on rtx's in my experience.
