T REX
This has happened to me twice when on the trail. Any thing over 1/8 throttle and the sled wants to die, almost like it hits a govenor. No error codes came up and the TORS is bypassed. I shut it off and went through the diagnostics and when I fired it back up everthing was good. Any suggestions?
Polly
I had same type of problem
On my RX1 I had something simlar and if you look at your throttle where it pivits by the thumb warmer there is 2 plastic washers(one on top and one on the bottom) where the pin goes thru. Check if there is any grease or sand. Some how grease got into mine and the throttle would bind slightly. Not enough for the TORS to react but once this was cleaned problem never occured again. It felt like the engine shuts down.
