alaskan77
07' Apex MTX, parked it in the trailer, now it won't stay running. Will only start with a battery charger on the jump setting and the throttle half open.
Fuel pump cycle does not sound right. It only clicks when I cycle the key. Once hooked up to the jump setting, the pump cycles, it turns over fine and will fire up with difficulty with the throttle opened but will die the minute I release the key.
No codes either...
Ideas?
No codes either...
Ideas?
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
When you turn the key on are you getting a display? What is your voltage at the battery jumper leads? These sleds have some known electrical issues but we need to know how it’s reacting07' Apex MTX, parked it in the trailer, now it won't stay running. Will only start with a battery charger on the jump setting and the throttle half open.
No codes either...
Ideas?
alaskan77
Yes, full display showing and no codes. I can get it to run with jump pack, but when I let go of the key it dies.
The battery is on the charger now. I'm hoping its just low voltage, but the key thing has got me.
Brotherdan
- Sep 8, 2017
- Belmont,maine
They do some strange things if the battery is bad,as your doing try charging first& if it wont take a charge replace battery & see if problem goes away,depending on battery age& if it went dead& froze will determine if it will recharge or notYes, full display showing and no codes. I can get it to run with jump pack, but when I let go of the key it dies.
I agree with Brotherdan, get that bad battery unhooked.
alaskan77
It was the battery. Could only get 11 volts after charging it overnight.
I guess I got my money's worth out of it, this will be the third battery in 17 Alaskan winters, 9500 miles.
Thank you both...
Thank you both...
