yamiluke94
- Dec 13, 2011
The sled runs fine over 4k, wouldn't that bearing, A: be noticeable at speed and B: keep it in limp mode not allowing any clean running
yamiluke94
- Dec 13, 2011
Problem solved!!!!
It was definitely the TPS sensor, pulled the trigger on a new one since the dealer had it in stock and said he would let me return it if it wasnt the issue. Plugged it in, entered diagnostic mode in the display and it showed 00, bolted it back on and adjusted it to 15, then adjusted the idle and away I went for a 30 minute trouble free ride. Glad thats over with.....
Good to hear.. Thanks for posting the fix.
yamiluke94
- Dec 13, 2011
No problem, thanks for all the help!
yamarog
tps sensor
where is the tps sensor plug location, any pics on bypassing it?
mine has a less but still noticeable erratic idle I'd like to try this as a troublr shoot, thanks
yamiluke94
- Dec 13, 2011
You can't bypass the TPS, but you can test it. You can bypass the TORS though. Tell me what you are trying to do and I'll be help you through it.
yamarog
want to bypass tors to see if thats my poor idle problem
yamiluke94
- Dec 13, 2011
Remove the pto side panel and below the headlights you will see a harness in a taco shell looking rubber boot. Remove that boot, the connectors you need are in it. There will be two separate single wire plugs, one is white, one is black. You unplug those and plug the black into the on the main harness... The other two wires running up to the bars can be left unplugged.
yamarog
Ok, very similar to the by-pass on the old 2-smokes, I've left more than a few like this and just ran them, is there any dangers to leaving them for exended time?
yamiluke94
- Dec 13, 2011
No, most people leave it unhooked and add a tether in case it does freeze up. W/o a tether there's the obvious danger of it taking off like a bat out of hell lol
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
yamiluke94 said:Problem solved!!!!It was definitely the TPS sensor, pulled the trigger on a new one since the dealer had it in stock and said he would let me return it if it wasnt the issue. Plugged it in, entered diagnostic mode in the display and it showed 00, bolted it back on and adjusted it to 15, then adjusted the idle and away I went for a 30 minute trouble free ride. Glad thats over with.....
I think im having the same issue. What did u have to adjusted after u put the new one on. Thanks
yamiluke94
- Dec 13, 2011
With the key off, push the select and mode buttons and hold them down. While holding those turn the key on and continue holding for 8 to 10 seconds. The display will show d1, let off the select and mode buttons and push them again holding them till the screen shows d01. Now when you push the throttle the screen will show you a #. Closd sshould be around 15 and open near 100.
