jsnow
Yes i have, they are a option! it is just quite abit cheaper to go through yamaha
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Gotcha good luck with the search and hope somebody or you can find the right parts or go aftermarket
jsnow
Thank you sir!
Anyone else have any info on this?
dubla92
Yamaha extro's will not fit the stock '10 drive shaft. The Yamaha extro's fit on a larger drive shaft. You would need to purchase the shaft as well.If you are on a budget try running the stockers. Your riding style may allow you to get away with stock non extro drivers. My riding buddy runs a rtx tretched to 136 with a 1.75 bc and he has had no ratcheting issues. He rides lots of off trail as well. Track is to tight side of spec but not over tight. With the dupont slides he has had no slide wear issues. Don't be fooled thinking with extros you will be able to run your track crazy loose. It will rub the top of the tunnel badly. You can only really run them on the loose side of stock spec. I would try it and see.
Use the parts fiche and check the drive shaft P#', they are different.
jsnow
ok thanks for the info!
jsnow
Ordered Whals from Ulmer!
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Nice
