RobWarrior
Back in my 2 stroke days my POLs would foul NGKs all the time...I tried Denso's and never had a plug foul again...thinking about running cr10ek cross reference Denso?
rbell14
Why? Are you experiencing fouled plugs? My stock plugs have always last a long time with no issues.
RobWarrior
I want to change them because the sled sat for a long time before I bought it...only 200 miles on an 09. I think one might be fouled because the only time I got to ride so far this year I started it after sitting for 5 minutes and it wouldn't rev up(no code?)...turned it off and started again and the same thing finally got it to move and it was fine after? I figure a plug change can't hurt?
bjowett
Denso produces good plugs.... No reason not to run them.
Since it sat, the fuel was/is likely garbage, and likely part of the problem.
RobWarrior
bjowett said:Denso produces good plugs.... No reason not to run them.
That's what I was thinking...I ran most of that fuel out after adding some startron so now is a good time for a plug change, I ordered the Denso cr10ek cross ref.
