MIRX1
- Feb 2, 2012
Hello all,
My 08 Nytro is not starting after off season storage. Just put new battery in, new plugs, it is getting fuel, and spark. I took out plugs and it seems to have compression based on covering plug hole.
Fuel pump is running with key on and I have no trouble codes. All fuses are fine and I have the red fuel pump relay already.
One thing I did note was the engine sounds a little off while cranking. Meaning, it sounds like it's pushing a lot of air into the airbox. I've had many Yamaha 4 strokes and this is a first. Anything else I can check or missed?
MIRX1
- Feb 2, 2012
I forgot to mention that it would not fire on starting fluid in airbox. Checked for spark at coil and it zapped me so I assume there is spark. Stuck valve??Hello all,
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I would definitely do a proper compression test and based on that, a leakdown test. Maybe your timing chain jumped.
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
Exact thing happened with my friends Phazer..... low compression. I put oil in the cylinders. Compression went way up. Put the plugs in and it fired right up... smoked like crazy. Once the oil was burnt off it died.
