apex aftermarket exhaust
yamy
madison mn
whats the lowest costing aftermarket exhaust for apex that sounds good, and the websites to find them
go with the get R dun exhaust from hauck powersprts and if you want a cheap one and still sounds good just hollow out your stock one it sounds pretty nice
I have heard these and they are pretty good and not going to get you a ticket.
http://cgi.ebay.com/ebaymotors/yamaha-a ... dZViewItem
I have seen these sell from the manufacturer for $250 buy it nows (blemished) but they are plated and should not rust.
I have 2 Hauck Gyt-R-Dun pipes and they are loud and have an issue. The resinator is in the center of the tunnel and steps from 2" to almost 4" and everything going through the tunnel catches on it. The flanges are riveted together and the rivets vibrate loose. I welded one the other is trashed from so many ice and rock hits. Studs are also a problem.
No pics I cut out 3 sides of the outer shield, then an inch in on th inner wrap peeled both back. Using 4" air cut off wheel. Cut out both cross over pipes inside the divider plates. Welded first shield up then 2nd and then welded 22 gauge panel over entire opening for re-inforcement. Did it all with pipe in the sled.
My job was just like the post above except the 07's and I think newer the Muffler is 2 layer outer shell. & I kept getting a little pin hole leak so I welded a plet over the entire opening to make sure it was sealed.
I just pulled into the driveway coming back from the UP. we went up yesterday morning did 280 miles from Ironwood to calumet and back from 1pm to 11pm. No other sleds there durning the week. Passed 7 sleds in to 280 trails like glass.
